W203 Coupe 2001 wiper / washer /can bus failure?
jungleboy
This morning i did not take my canoe to work but it became clear after a small clunk and the complete failure of my window wipers that perhaps i should have.
It doesn t seem to be anything mechanical as the wipers returned to the home position after a small shove.
Further investigation has shown the relays are fine as are the fuses
However , i note with interest that the window washers have also failed , these belong to the same can bus "group"
I know very little about the can bus but know a man that does , though not in the MB context. Is there anything that could cause this "group" to fail?
Thank you all in advance
I m off to swim home http://forums.mercedesclub.org.uk/images/smilies/icon_sad.gif
Sounds like it all needs lubricating
J
jungleboy
intermittent now , joy.....
Yes , i was surprised at the facti could push the wipers to , then i noted the absence of window washers.......
I ve actually just put the car in the garage and noted that and the washers and wipers came back , so still thinking its a can bus problem....
Thaks for replying guys
Try slamming the bonnet shut, you have a wiper "kill" switch on a 203 which is built into the o/s bonnet catch!!
J
jungleboy
oh ~@[}~@{}~ @@@@ @@##
the bonnet kill switch would tie in perfectly with the intermittent fault , does the kill switch also cover the washers?
Regardless , SAM UNIT , you are a legend
Yes it do!!!:D:D:D:D
