W203 Heater Booster question.
Martin Jennings
North Walsham, Norfolk
C204 250 CDi AMG Prem Plus, W168 A160 Elegance LWB
Afternoon all, I have the dreaded battery drain on my 220 CDi and after speaking to Alex earlier this damn booster seems the likely culprit! After searching the forum it seems there is no fuse/relay to control or isolate this thing but on going through my dash board settings i had the booster set to "auto", now set it to "off". I have a feeling it is not that easy to stop it draining my battery but can anyone advise if the only way is to literally take the feed off it?
mersum1es
Finland
I recall one case mentioned it has helped. Otherwise you have to disconnect feed wire. Difficult, yes.
mersum1es
Finland
Martin Jennings
Martin Jennings
ok, thanks, I had a feeling this would be the case, I think it will be on its way to Alex's for this one!
Martin Jennings
Martin Jennings
Does anyone have a photo/diagram for the feed cable to this heater booster please?
Martin Jennings
Martin Jennings
Ok, an update on this. Car has been left with Alex Crow and he found the problem (naturally). It's the instrument binnacle at fault and not allowing the car to go to "sleep". Binnacle has been sent away for diagnosis and hopefully repair but if knackered I will have to source a 2nd hand one.
Martin Jennings
Martin Jennings
Ok, update time! My Binnacle was re-cycle only but the company Alex uses had another one which was loaded with all the data from my scrap one and coded to the car and all is now well! Hope this is useful to anyone with a battery drain on a W203 as an alternative to the coolant heater booster fault. The original binnacle was keeping the interior CAN bus awake even when the car was locked so draining it overnight. Top marks again to Alex for finding it!
www.ckinsurance.co.uk
