w203 indicator bulb
You have to remove the mirror cover, I can send you the info on doing this if I had your Email address
I have sent you the instruction via E mail
With an Email address yes
Chris-net
[2011 S212 e250] [2021 W213 A238 E53]
Hi television,
tried PM'ing you but your pm store is full.
i would be grateful if you could send the disassembly instructions as i have an intermittent fault with the drivers side indicator. works when retracted but fails when extended.
many thanks
Chris
Sorry my PM box has to stay full
You can pop your address up here of an evening when I am posting and remove it in edit within 4 hours
namanesu
Electric folding mirror - indicator disassembly
Hi Television
I have been trying to follow instruction to replace the led lights but the silver clip is not budging. Is it possible to get some instructions. I know this is an old thread but hoping you still have the instructions handy
Thank you
I still have the papers for cars up to 035817 there is a change after that date
namanesu
Indicator led
Thank you both for quick response. I have seen the video but mine doesn't seem to loosen the cover by pushing the silver clip. It doesn't look like the original mirror anyway so God knows what year it is from. I have pushed so hard I have managed to break a piece off. The whole unit is a bit loose after trying to pull case. Is there anyway to realign back in? Is there an alternative way to disassemble it. I have seen a long disassembly but it's for the slk.
Thank you
