W203 key problem
Mick taylor
C200k 2002. 2.0
Hi. My car is a 2002 C200 kompressor. W203. My problem is when I put the key into the ignition it doesn’t always unlock the ignition/steering. Sometimes it’ll work second or third time but other times I can put the key in and out 20 or 30 times before the solenoid clicks. I’ve tested the battery and it’s producing over 12 volts. Is it the key or the ignition switch that is faulty? Thanks in advance for any light you can shine on this problem.
GlosRichCLK
Gloucestershire
Do you have a spare key to try?
Mick taylor
C200k 2002. 2.0
I do but it’s dead. Even the red light wont flash. Been like it before this problem arose
AMGeed
Poole, Dorset
S204 C180K
I would take an educated guess that the EIS is failing. It can be repaired but it needs proper diagnosis first.
You need to find an indy (MB tech outside of main dealer) with STAR diagnosis system that can pinpoint the problem.
No idea of your location, but RMK in Birmingham can repair both the EIS or any key.
http://www.replacementmercedeskeys.co.uk/
Edit.This guy is a forum supporter and can probably assist. Based in London.
https://www.ecu-repair.co.uk/
Mick taylor
C200k 2002. 2.0
Mick taylor
C200k 2002. 2.0
Ok thanks. I’ve emailed both places and will let you know what they say
