W203 seat removal
Dazzler
Haverhill, Suffolk
W211 E320 CDi Estate 05
Any tips on how to remove the seat base leather as i want to repair/replace the heat pad?
Have these seats got airbags in them?
Malcolm:rolleyes::razz:
I have sent the info to you
Norman59
Europe
W203 180K Coupe
New project :) I want to remove the seats, can you help me with the instructions for that?
xxxxxx
I have sent what I have and you can edit out the address :D
Norman59
Europe
W203 180K Coupe
Thanks, just forgot to mention it's for a coupe model, so the back seats are a little different :Oops:
I will have the other computer on later in the day and I will try and print off the CLC seats for you
doyley
manchester
C220 CDI Coupe
Hi all sorry to resurrect an old thread but i was wondering if anyone had any instructions on removing the seats (front and back) from a W203 coupe, Iv bought a set of leather ones on ebay and want to have a go at swapping them any help much appreciated.
You just disconnect the wiring under the front seat rail, and unscrew the 10mm bolts holding it down,, the rear squab lifts up and out, then remove the backrest screws and lift the backrest up and out.
doyley
manchester
C220 CDI Coupe
Thanks for the quick response Television!...I might be back as I'm a complete amateur with a Ratchet set!! cheers
cleverdicky
MB
Keep the key out of ignition the whole time or you will get faults.
Good luck with swapping to the leather, damn hard work - but worth it.
Takes about 1/2 day per seat
Jim55
Glasgow
220 cdi sport
Thread resurrection
Does keeping key out the way to do it , it's just a matter of bolts wires if I want to change them
If the ignition is turned on with a seat unplugged/ removed, the SRS warning lamp will need STAR to turn it off
Jim55
Glasgow
220 cdi sport
My car has electric seats , but unfortunately they aren't heated , if I got new seats with a heating element in them and proper dash switches could I just retro fit them and not have bother with sensors going off
It is the seat belt sensors, and all seats have these no matter if heated or not. the heated part does not come into it.
Jim55
Glasgow
220 cdi sport
So it will trigger sensors then ? It's basically a no go for a swap?:confused:
Not at all, your new seat will have seat belt sensors built in, all I am saying is do not turn on the ignition with the yellow plugs (the SRS ) disconnected while changing seats, or if you do the car will need to be plugged into STAR to turn the lamp off.
