W203 - Sudden loss of power and engine cut out
Discussion in 'Engine, Drivetrain, Fuel and Exhaust' started by Hustler, May 14, 2019.
  1. Hustler
    Hustler Senior Member
    106
    7
    Nov 25, 2012
    United Kingdom
    Your Mercedes:
    2003 C200 Kompressor Coupe 1.8L
    Hi guys,
    Today my car suddenly lost power and the engine had cut out whilst driving. The engine would not start again and it would make a similar sound to this (from the 26 seconds mark):
    The vehicle cranks but would not start
    I had to call recovery and the recovery guy did some tests. He vaguely concluded at the roadside that it looks like there's no fuel pressure but he didn't really look into it much.The vehicle has been taken by the recovery company to the garage who will check it out tomorrow.
    When it was brought to the garage after around 2 hours after the incident, the car started fine (although it seemed a little rough). Guy at the garage said it sounded like a misfire but they would keep the car and do the checks tomorrow.
    In the meantime, I'd appreciate if anyone could point me in the right direction as to what the issue may be.
    It had the fuel filter changed 4 weeks ago and for the last few days I noticed a slight 'rattle' right when I start the engine.
    There is an oil leak from the camshaft magnets which has been baked on for a few years and it has the oil-trap harness fitted.
    Any guidance would be most appreciated.
    Thank you
    M271 engine - 2003 C200 Kompressor Coupe, 1.8L Petrol, Manual
  2. LostKiwi
    LostKiwi Senior Member
    17,038
    7,548
    Aug 25, 2006
    Your Mercedes:
    '93 500SL-32, '01 W210 Estate E240, 02 R230 SL500 (Malcolm Spec), 04 Smart Roadster Coupe
    You could have encountered the cheese timing sprocket issue.
    Google m271 issues.
    Do not turn the engine over until you remove the cam cover and check the cam sprockets.
  3. OP
    Hustler
    106
    7
    Nov 25, 2012
    United Kingdom
    Your Mercedes:
    Hmm, I'm not convinced it's the infamous 271 timing issue (yet). Signs indicate no fuel pressure and the engine did start a few hours later at the garage - at which point he kept revving it till 4k rpm. :eek: Really praying it's not the timing issue you say it is otherwise it's toast.
  4. LostKiwi
    17,038
    7,548
    Aug 25, 2006
    Your Mercedes:
    It was the mention of the cold start rattle. Classic warning symptom.
  5. star
    star Forum Supporter Authorised Forum Supporter
    5,033
    457
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    vid is c240 not a c180??
  6. Steve@Avantgarde
    Steve@Avantgarde Forum Supporter Authorised Forum Supporter
    6,724
    871
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Mercedes-Benz C32AMG, SL55AMG, C320CDI Sport Edition Estate and SLR McLaren Coupe Roadster.
    Well...
    It could be the fuel pump, a fuel pressure test would confirm that and its easy to do - but a discerning technician by ear would also tell you by listening to it if it has lost compression and you have a timing chain issue.
  7. star
    5,033
    457
    Oct 6, 2004
    Reading
    Your Mercedes:
    Smart + others :)
    We have seen 271 chains let go without having a rattle on start up.
  8. OP
    Hustler
    106
    7
    Nov 25, 2012
    United Kingdom
    Your Mercedes:
    Vid was just for demonstrating how it sounded when trying to start up, my car is a C200K
    Thanks. I'd rather the fuel pump than the chain.
    I've been reading on other forums people mentioning camshaft sensors? Could this be a possible line of enquiry in my case?
  9. Steve@Avantgarde
    6,724
    871
    Dec 8, 2009
    Bristol/Somerset
    Your Mercedes:
    Unlikely to be a crank/sensor.
Share This Page
