W203 track rod end question?
Rich-J
Cheshire
C220 cdi estate '04
Changed the anti roll bar bush's yesterday and the upper suspension arms and noticed that with the track rod ends from the steering rack where the ball joint connects to the hub I could move them quite freely, to me this means they's have better days yeah?
Also if I do change I take it mark where the others were on the threared area and tighten up to that mark not to upset the steering to much yeah?
Thanks in advance:)
Rich
LYNALL
Kent
If you mean you can twist them, thats perfectly okay, but if they have lift in them when the steering is rocked thats another matter.
Marking the threads will be fine to get you to a garage to get the tracking reset.
Lynall
R
Rich-J
Cheshire
C220 cdi estate '04
Yeah I can twist them other than that then they are fine, thx for the reply
As LYNALL with these ends if you just slacken the lock nut a ½ turn,put the new ones on and do up the lock nut, and if you replace with MB joints they will be as near as dam it right.
Though as you say you do not need them if the is no free play
R
Rich-J
Cheshire
C220 cdi estate '04
My only worry is I've changed anti roll bar bush, drop links, upper suspension arm and still get a slight clunk/click when braking from the front left?
Any ideas as Im only left with lower arm and track rod end.
I would check the swivel joint on the bottom,,use an iron bar to lift it up,, that the best way to tell
R
Rich-J
Cheshire
C220 cdi estate '04
Swivel joint? Is that the lower suspension arm? If not do you have a pic?
Thanks Malcolm
R
Rich-J
Cheshire
C220 cdi estate '04
Will try that as I've changed 90, so 140 is the other suspension arm ain't it. Take it best change in pairs if knackered.
Thx
Thx
While you are at it yes in a way though the nearside take more of a hammering than the off side , though on my SL the off side is worse
R
Rich-J
Cheshire
C220 cdi estate '04
Will try that, so far this is turning out to be an expensive excercise lol Guess once its done its good for a few years.
Would the car need tracking once done as that arm takes the most brunt doesn't from the road etc.
Thx for the advice so far big help:)
No need to track,, and there may be nothing wrong with that joint
R
Rich-J
Cheshire
C220 cdi estate '04
If not any ideas as Im clean out of ideas then?
Not really , I am not even sure that you can hear the bottom swivels
R
Rich-J
Cheshire
C220 cdi estate '04
Unless the ball joint has come clean away but sure I would have noticed by now lol For what they cost may just try it as its simple enough really.
LYNALL
Kent
Item 140 is the alloy arms i had to change these on wifes car as they were totally shot.
Look at the rubber bush and if you can see any crack even hairline its had it.
Pic is of offending arm when fitted to car theses cracks were miniscule.
Lynall
