Hustler
- Nov 25, 2012
- Location
- United Kingdom
- 2003 C200 Kompressor Coupe 1.8L
Hi Guys
I've long had an ABS/ESP/BAS malfunction warning on my dash and discovered about a year ago that it was probably something to do with water getting into the trunk/boot but I didn't know exactly where.
After doing some Googling yesterday, I decided to strip down the flooring material on the boot and check out that area of the boot.
Here's how it looked:
and here's a closeup:
As you can see there's been some corrosion on the connectors and copper wire of the speed sensor connection part. This was the only area that was slightly damp, the rest seemed pretty dry having possibly dried over some time.
I've doused the area with WD-40 Contact Cleaner numerous times and tried cleaning the area and contacts of the cable and the speed sensor as best as I could hoping that it will work. Also completely hairdryed the area so it's completely dry now.
However, I've driven the car around the block a few times but the ABS/BAS/ESP error has not gone so I was pretty disappointed. Also done the lock-to-lock reset trick but that doesn't work at all either.
I'm hoping the yaw sensor is perfectly fine because apart from the white spotty rusty-like casing, the unit itself seems completely dry and the wiring to the sensor is also completely dry and looks like new.
What I wanted to know is whether I need to take the vehicle to the garage and have the error reset or should the error message just extinguish itself?
Also, is there a way I could test the connection with a multimeter (If so, what setting do I put and what results should I expect)?
Finally, is there anything else I should do that I've missed? I was thinking of taking the wire out and recutting and then re-inserting back into the plastic connector but pulling the wire out of the connector seems to require a lot of force so I imagine putting it back in would be even more painstaking. :| Something tells me the contact cleaner and scraping the connections with a small safety pin hasn't done a good job:
Would really appreciate some help as it feels like I'm close to getting it fixed but I don't know what I should do. Hoping the experts here can give me some advice
Thank you!
I should mention that i'm no mechanic and have limited 'knowledge 'in vehicle troubleshooting and repairs. :Oops:
Thank you!
