Steve Taxi
I think I have seen this posted before, the washers work fine with the engine off but when its running the pump runs for 2 secs and then stops, it will do this maybe 3 or 4 times and then run continuously on the 5th go, why should the engine running effect the washers? they work ok at key position 1 and 2 but start the engine and they do as above, this is a pain because I need the w/washers when Im moving mainly!!
