I wonder if anyone can help me. I have a 2014 mere c180 1.6 cgi. The thermostat temp. is running just below 80c and I checked this wit an OBDII reader and it confirms a lower the normal temp. Further the temp. drop when standing at light etc.
So I asked Merc about a replacement and the unit it's self cost £100 and seams to come with the hole housing. Further it looks like to access from the top the following need removing
1. Air Box
2. Air intake pipe
3. Air pipe to turbo.
4. ECU
5. Input manifold
Access from the bottom looks limited too. I don't have the procedure for remove/replacing the manifold.
Anyone any ideas on this one?
Further the coolant looks clear i.e. not coloured which is not what I would expect. Im planning to test the coolant when I get change , but does this sound right?
1. Air Box
2. Air intake pipe
4. ECU
5. Input manifold
