W204 C200 CDI - Possible Propshaft guibo/donut/flex joint and bearing ??
dickybow
Birmingham
C200
Hello
Car: 2008 C200 CDI 190,000 miles
There is a 'wobble' noise and vibration at 40-50mph that seems to stop when you put the car into neutral.
Is it possible that this is a worn propshaft guibo/donut ?
Advice gratefully received
DREAMER NO2
W124 2.6E M103 1989
You wont know till it on a 4 post lift .
Then inspect the propshaft rubber couplings if its a rear wheel drive that is and also the centre bearing you might have two couplings one front one rear .Your looking for splits in the rubber and damage .And if it is the couplings then get them sorter asap or see picture . 300SDL_rear_tran01.jpg
DREAMER NO2
W124 2.6E M103 1989
You need to inspect the propshaft coiuplings for wear , along with centre bearing. Most new Mercedes withthe larger type engine the silencer will need removing to get at the guibo rubber couplings .Good luck .
Steve@Avantgarde
Bristol/Somerset
I would look at the rubber mounts of the engine and gearbox rather than the prop. Terribly common failures that cause vibrations, wobbles and droaning noises.
