whitegold
- Aug 11, 2005
- Location
- East Yorkshire
- C220 cdi Blue Efficiency SE MY2012
Hello all, I wonder if some kind person with WIS access could post the Torque setting for the Exhaust Manifold Connector A6511530056 which sits between the EGT sensor and the manifold?
Apparently this spacer is used in EURO 5 Sprinter Vans as well as the Blue Efficiency cars with OM651 etc.
I understand the sensor itself should be 45NM but can't find any reference to the spacer which screws directly into the manifold without a gasket.
Reading some other posts on changing theis sensor, it seems to get seized into the connector, and can only be loosened with the connector in a vice. That was my experience, however it was so tight that even when heated and held in a vice, it was immobile and eventually broke off.
