W204 c220 coupe 15 plate tyre issue
Discussion in 'Bodywork, Tyres, Wheels & Trim' started by Rob Brown, Feb 6, 2020.
  1. Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    Hi all, can anyone advise what tyre size should be on the rears of a c220 coupe? I've put some 19's on but the tyres seem to be really rubbing on the car. I bought them from someone who had a c250 so I didn't think there would be an issue but it's really not a good ride. I've put the current size up and what the alloys look like on the car.
    Thanks in advance!!
  2. JBell
    JBell Senior Member
    11,413
    3,334
    Dec 9, 2011
    Torquey
    Your Mercedes:
    C350 CDi Estate (GAD Edition)
    Wheels:
    Front: 8Jx19 ET45
    Rear: 9Jx19 ET54
    Tyres:
    Front: 225/35R19
    Rear: 255/30R19
    Your rear tyres are way too big
  3. OP
    Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    Thanks mate, really appreciate it!! On the hunt now so....
  4. OP
    Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    I've got 235/35 on the front, do you think they will be alright?
  5. Bubble
    Bubble Senior Member
    334
    136
    Feb 20, 2013
    Braintree
    Your Mercedes:
    E350 Coupe CDI / Land-Rover Discovery 4 / Nissan Skyline 650bhp R.I.P.
    The offset looks completely wrong to me, as they stick out much too far.
  6. onefortheroad
    onefortheroad Senior Member
    1,093
    305
    Dec 8, 2015
    uk.
    Your Mercedes:
    c250 amg premium 2 door coupe.
    At 70 mph with 235 35 19 . Youre doing 72 mph. The sidewall is also higher even though its 35 profile. So if you fit the correct tyres on the rear the cars profile will be wrong ..
  7. KennyN
    KennyN Senior Member
    1,259
    436
    Dec 18, 2013
    Paisley
    Your Mercedes:
    BMW 440i, ZX12r / ZRX11 / ZRX Monoshock
    Agree with the above , either that or you are running spacers that are too big.
    What offset (ET) are the new wheels ?
    K
  8. OP
    Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    So basically, I've been quite stupid on this. I bought these wheels with not great tyres as I thought (and still do) the alloys would look good on the car. I saw the pic of the wheels on the vehicle which was a c250 so I didn't think for a minute I'd have an issue with tyre sizing. I've since replaced the fronts with 235/35/19 and as you can see the backs are awful (currently 265/35/19) so they need to come off ASAP.
    So as it stands I will be replacing the backs with 255/30/19 but my question is do I need to replace my 45mile old Michelin PS4' 235/35/19 with 225/35/19?
    There's a lesson to be learnt here but that's for another day....
  9. Bubble
    334
    136
    Feb 20, 2013
    Braintree
    Your Mercedes:
    I don't think that it is the the size that is the issue.
    On my E350 Coupe I am running 275/35x18 on the rear, where standard is 255/35x18. This gives just 10mm extra wider each side, to help protect the wheel rim from kerbs. They look fine, don't rub and you wouldn't know that they were wider unless you checked the size.
    The wheels that you have look similar to my Chinese copy winter wheels and they stick out further than the standard AMG wheels, but not to the extent of yours.
    I think that you would be better off keeping your new tyres, selling the wheels and getting some new wheels with the correct offset.
  10. OP
    Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    I didn't for 1 minute think there would be an issue because these are where the wheels came from.
    Thanks Bubble I appreciate the advice. I believe the wheels offset is this;
    Fronts:- 19x8J - ET35
    Rears:- 19x9J - ET38
    Is that wrong?
  11. AMGeed
    AMGeed Senior Member
    6,392
    2,562
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    2014 W212 E63 Biturbo
    Yes, both offsets are wrong.
    For a W204 C220 on 19" wheels you should have the following offsets
    Front ET 45
    Rear ET 54
    This website might be handy to check offsets and part #'s should you want to get OEM MB wheels.
    https://www.alloywheelsdirect.net/mercedes_alloy_wheels/c_class_saloon_w204_alloys
  12. Bubble
    334
    136
    Feb 20, 2013
    Braintree
    Your Mercedes:
    I honestly don't know the answer to that, but I do know that the lower the ET number, the more the wheels will "stick out"
    Good luck with getting a good result!
  13. OP
    Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    When you say wrong, is it that they won't fit on the car or just it's not ideal? Am i fighting a losing battle with these?
  14. Gazwould
    Gazwould Senior Member
    1,092
    525
    Oct 28, 2018
    Your Mercedes:
    S204 OM651
    And another lesson , some 255 tyres might be 265 !
  15. JBell
    JBell Senior Member
    11,413
    3,334
    Dec 9, 2011
    Torquey
    Your Mercedes:
    No, they are fine
  16. JBell
    JBell Senior Member
    11,413
    3,334
    Dec 9, 2011
    Torquey
    Your Mercedes:
    10mm on the front will make no difference, there is loads of room in the arch, the rear is a different matter, the current tyre is way too big so putting a smaller one on will help the problem
  17. OP
    Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    Thanks mate, the tyre I'm going with is a 255/30/19..... That should do it I think?
  18. OP
    Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    Just wanted to say a massive thank you for all those that have helped me on this. Gone for these;
  19. JBell
    JBell Senior Member
    11,413
    3,334
    Dec 9, 2011
    Torquey
    Your Mercedes:
    Nice wheels
  20. OP
    Rob Brown
    Rob Brown Member
    21
    Feb 2, 2020
    Your Mercedes:
    W204 c220 coupe
    Thanks mate, went with the offsets you kindly said
    JBell likes this.
Share This Page
