steve gooding
- Jan 15, 2018
- 2012 C220 Sport CDI estate
Hi peeps, this is more of a sanity check than anything.
When I first bought my car 18 months ago (2012 c220 cdi sport), I had it serviced more or less immediately. One of the advisories was front torque arms showing slight wear, and was told it’s not urgent, it could be done next time. However, when I had the car serviced again this year, nothing was mentioned. I asked the guys if they seemed ok, he said he was hanging off them while it was on the ramp and they seemed fine...
I have noticed though the front suspension seems very clunky over bumps and it’s more noticeable when braking. Could this be torque arms, or a ball joint? I can’t see any fluid leaking from the torque arm bushes..
A bit more worrying though is when I brake hard at high speed. The car seems to initially twist when first hitting the brakes, but there is no pull on the steering, and does stay in a straight line. It’s just that initial application of the brake. This suggests to me some sort of wear in the suspension, but could it all be down to torque arms?
Sorry for the long post, I just want to be sure before I start spending a shed load on something that may not cure the problem...
TIA
Steve
TIA
Steve
