W204 Throttle valve leak
potterwoz
2013 C250 Coupe
Afternoon all.
Bit of a follow up to a thread on the suspension section but I've recently been under my car a lot.
I've found what seems to be an oil leak from the (charge) air pipe into the bottom of the throttle valve.
Has anybody had such issues before? Maybe a seal has gone on the valve? I've had a look for part numbers for seals etc but can't find them ****** anywhere!
I'm also hoping it's not a turbo seal or my turbo on its way out as nobody wants that no loss of performance etc. Just something I noticed the other day.
Thanks for any info
P
potterwoz
2013 C250 Coupe
The oil is running down this pipe from under the throttle valve!
Sent from my VOG-L09 using Tapatalk
P
potterwoz
2013 C250 Coupe
Hi there.
Just updating for those who may have the same problem (always helpful).
Had the car fault codes read and it’s thrown up P200A75 - The charge movement flap (cylinder bank 1) has a malfunction. The emergency position was not reached.: stored.
I imagine this is due to the build up of soot and carbon over the 94k I’ve done in the car so I plan on removing the EGR, Throttle valve and intake manifold to give it all a good clean.
The Indy has said however that removing the intake manifold and throttle body is dangerous as if I move the flaps they will lose the position memory and it has to be sent to dealer to calibrate them. Is anybody aware of this.?
Thanks in advance
