W204 weird sound, Dashboard flashing and passenger airbag flashing
NewbietoMB
C250cdi 2010 w204
Hey guys ,
Just started the car today after driving 5 minutes this weird noise started to come and the passenger airbag light started flashing with the dashboard also flickering.
I’ve attached videos hopefully you could help thanks so much I’m advanced .
W204 c250 cdi 2010
N
NewbietoMB
C250cdi 2010 w204
  • #2
Just had AA out and they said …. “ Metallic sound, turbo, or flywheel needs further investigation “ got towed to an garage so will see tomorrow
N
NewbietoMB
C250cdi 2010 w204
Rotorhead500
Very South Devon
Used to have a C63...
Hello. Sorry to hear you've issues.
Not sure turbo issues would cause the electrical gremlins!
Car does need to go to a decent MB specialist - what area are you in? There are some very good independent specialists on here, hopefully you can get the car recovered to one of them for diagnostics!
Edit: Just had a re-read... wondering if metallic noise is alternator eating itself and resultant voltage issue is causing your dash & airbag lights??? (Or you've got two separate issues!)
N
NewbietoMB
C250cdi 2010 w204
Hi there rotor head thanks for your input :)
I’ve dropped the car off to Leicester Star Motors Merc specialists let’s see what happens will update shortly :)
Rotorhead500
Very South Devon
Good work, keep us posted. Always useful to hear what gremlins are at work!
N
NewbietoMB
C250cdi 2010 w204
Hi just an update . It was the starter motor . I thankfully got it replaced under AA parts and garage cover and it resolved the issue . Thanks
www.W140.co.uk&www.r129.co
