Operations
- Jan 7, 2021
- W204 - C350 - 2007
Like i said in my "which waterpump" topic, i am having a weird issue with my 2007 C350.
Car has got 186000 kilometers on it. Belt and rolls (including the one that tights the belt, sorry don't know what the correct name is) have been replaced. Radiator doesn't have a leak, car doesn't leak any cooling fluid at all. Fluid has been replaced with new G13.
First i will also explain in this topic what the original problem is, which made us decide to change the thermostat and water pump.
When the car is at normal temperature
(after 30 min highway) and i reach a street or a traffic light, the fan goes up to a 140% . According to my simple icarsoft device this is done at the request of the engine (so NOT the AC).
We have also checked the car with Xentry, and what happens is the cooling fluid reaches 110 / 112 degrees. We couldnt really find a reason why, except that according to my mechanic friend the thermostat opens quit late. So he/we figured it probably is the thermostat, which isn't 100%. So any other thoughts are of course more than welcome.
So we will replace this and because we are working on the car at that moment (and i also have to drive for a hour to get there so we often combine things), we will also replace the waterpump. Which technically could also be (a part of) the problem. Correct me if i am wrong, i am a computer nerd not a car nerd.
So at this moment the SKF waterpump is running fine, only for a day or so but it fits fine and we didn't came across any problems.
Replacing the Wahler thermostat with a new Wahler thermostat is a whole different story... The thermostat fits fine but the hole for the hose is too wide. And because of this the hose leaks fluid. Let me explain:
When we plug the hose in the hole of the old thermastat, you have to apply a bit of force. When it's in, it's in so to speak. When we put the hose in the hole of the new thermostat, it has room to move and it goes in without hardly applying any pressure.
Because i needed the car we put the old one back for now. I forgot to measure both the holes to "proof" my point, but the difference is easily noticeable.
This seems weird to me, the original part is also a Wahler. I didn't order an OEM part, which i will do now... I ordered an aftermarket Wahler at Autodoc.com. Based on my license plate, and they only sell one Wahler thermostat for my car. So it is not like i ordered a wrong one. Autodoc is a german supplier/website.
FYI my engine code ends at 056
But looking at the original one this one looks exactly the same, Mercedes did remove the Wahler part number
So i don't really get why the new Wahler thermostat is different. Like i said i will and should have ordered the OEM one (which will most likely be the same as i have bought already, had to imagine that MB would change the hole size... right?...), but this feels strange to me.
TLDR; fan is at 140% because cool fluid get 110 degrees, why? Appearently a thermostat Wahler is not always the same?
Any ideas about my problem? And any thoughts on the thermostat issue? I apologize for the long story but i wanted to share as much info as possible...
