KillerHERTZ
- May 11, 2003
- Location
- Cambridge
- Website
- www.youtube.com
- W463 G55 AMG
Mercedes introduced the W201 in 1982 as the precursor of the C-Class, which went on to become its best-selling series lineup. After nearly 40 years on the market and six generations (including the original 190 series), the C-Class has racked up more than 10.5 million sales. The time has come for a new generation that will try to continue the success of its predecessors despite competing in an SUV-hungry market.
The German luxury brand is not wasting any time as the sedan is being joined from day one by the more practical wagon, which will continue to remain a forbidden fruit in the United States. As expected, the exterior design is not a major departure from the outgoing model, but Mercedes has implemented enough changes to make the C-Class feel fresh for 2021.
It follows the sharper headlight design theme seen in the bigger models and adopts a cleaner side profile with reduced lines. The US-spec model will be available with a choice between 18- and 19-inch wheels whereas its European counterpart is also getting a smaller 17-inch set. At the back, the W206 generation is the first C-Class to have two-piece taillights, bringing the model in line with the more expensive E-Class and S-Class.
From the outside, some would argue it’s more along the lines of a significant facelift rather than a next-generation model, but that all changes once you hop inside the cabin. No, we haven’t made an error while uploading these images as these do show the new C-Class rather than the latest S-Class. The screen-heavy setup has trickled down from the crown jewel of the Mercedes lineup.
In North America, the 12.3-inch digital instrument cluster will be standard, and so will the 11.9-inch touchscreen for the second-generation MBUX infotainment system. Over in Europe, lesser trim levels will make do with a smaller 10.25-inch driver’s display and a more compact 9.5-inch center screen. The interior will be more spacious than before as a result of stretching the wheelbase by one inch (25 mm), now at 112.8 in (2,865 mm).
Speaking of dimensions, the new C-Class is 2.5 in (65 mm) longer and 0.5 in (10 mm) wider compared to the model it replaces and has a sleeker stance thanks to a slightly lowered roofline. As a result of its increased footprint, there’s more headroom, elbow room, and shoulder room at the front and rear, with passengers sitting in the back also enjoying more legroom.
The European C-Class also gets C200 / C200 4Matic gasoline models with a smaller 1.5-liter developing 201 hp (150 kW) and 221 lb-ft (300 Nm), plus the aforementioned boost from the ISG. The all-paw model reaches 62 mph (100 km/h) in 7.1 seconds in both sedan and wagon flavors while the RWD models do the job in 7.3 seconds (sedan) and 7.5 seconds (wagon).
In terms of top speed, the AWD-equipped C200 sedan and wagon reach 150 mph (241 km/h) compared to the 153 mph (246 km/h) velocity of the RWD sedan and 149 mph (240 km/h) of the RWD wagon.
A base C180 will be available in Europe exclusively with RWD and the 1.5-liter dialed down to 167 hp (125 kW) and 184 lb-ft (250 Nm). This one too has the ISG, contributing to a decent sprint to 62 mph in 8.6 seconds before the car reaches 144 mph (231 km/h) regardless of the body style.
