- Dec 8, 2009
- Location
- Bristol/Somerset
- Website
- www.avantgarde-automotive.co.uk
- E300 Coupe AMG Line PP/NE, SLR McLaren Roadster, SL55 & C32AMG
Hi Everyone,
I am having a real big issue with a facelifted W208 coupe. I cannot get the front windows to normalise.
The car came in with the O/S window stuck down. The window had frozen closed (because of the weather) and the customers persistant trying to put the window down eventually bent the regulator away from the motor teeth and that was the reason for that.
I fitted a new regulator and motor, with no dramas, and went to normalise the window but as soon as it hit the top the window went down 2 inches and stopped.
Connected star, DCM 1, control unit adaptations, denormalise window proceedure carried out, try to normalise via switch, still doing the same.
Checked actual values whilst operating the window and the hall sensor count isnt moving and is way out of spec (stuck at 65595 counts, spec should be -65000-+170).
The thought I had was that maybe I had a dodgy window motor sent through and that the DCM wasn't seeing the hall sensor counts so I got Benz Exeter to send me a new one, replaced that yesterday, tried to normalise through star again, still the window drops.
Disconnected battery and left for an hour to see if that would reset the DCM internally, same fault after doing this.
I then thought of using the left DCM plugged into the right motor, if it normalised the motor I might have a DCM gone down. After swapping over and trying proceedure still the same fault happening. Reconnected DCMs to correct side and now both windows doing it!! Argggg
Checked can lines to make sure high and low were working and there were no comms errors - all ok.
I then lost interest and drove it to my mate who is an indie in Bristol last night as I couldn't see anything I was doing wrong. We were on it until 9pm and He did everything exactly the same as I did, and we then both drew a blank, we had the thing on 4 different star machines to see if it was a software issue in the star not allowing it to denormaise properly.
He seemed to think it could be that the DCM's are still normalised and that the DCM's wont denormalised even though star says that the DCM's are denormalised!! Confused? I am. I cannot get my tiny brain around this one but if anyone has had similar issues I will welcome your insight and knowledge as I am stuck.
If you have got to the bottom of this long thread without getting bored and are still reading I will thank you for your time in advance!
Steve
Steve
