W209 CLK 220CDI Remote window closure
nikolaymk
London
2006 56 W209 CLK220 CDI Avantgarde Auto
I just got a 2006 CLK220 CDI and have a small problem with the electrics. The side windows open remotely but for some reason don't close when locking the car. I press and hold the lock button without releasing but no joy. They work perfectly from the interior switches.
I just replaced the key batteries and try from a very close range to the driver's door handle IR receiver but the windows won't go up.
Any ideas?
Many thanks for your help!
Nick
An all too common problem with the convenience feature, only by putting the car on STAR can one see what is not working
N
nikolaymk
London
Thanks for the quick reply Malcolm, is there a way to try to reset the convenience module before trying the diagnostics?
You can re set your key buy placing it in the ignition switch and pressing any button on the remote twice within 4 seconds
N
nikolaymk
London
Tried key reset, the windows finally started closing remotely but will keep an eye on them. Thanks very much for the advice!
For this operation it does require 2 presses of the key, press once to lock the car, press again to totally close
gh3382
North East England
W164 ML350
Is the convienence feature standard on this model as I have tried everything on the above posts with no luck.
gh3382
Yes its on all the cars, and you should have it,, if it does not work try the re set above
whitenemesis
CLS55 AMG '05
On the 203 its' press and hold. Been trying it over the last couple of days and it's very hit 'n miss, seems no logic as to when it works and when it doesn't...
Even my old 140 works well with this feature, try and re sync your key Peter, place in ignition and press any button within 4 seconds, my 230 always worked and so does my 216, I think that you are just doing it all wrong :D
whitenemesis
CLS55 AMG '05
Not changed how I do Malc. It used to work very well up to about 2yrs ago..
I'll try the re-sync
whitenemesis
CLS55 AMG '05
Well I'm buggered!!
The handbook does say "press and hold the button after unlocking the car"
You are correct Malcolm, again...
Well I'm buggered!!
No one knows it all Peter, look at what we learn every day on here :D
gh3382
North East England
W164 ML350
Hi Guys
No luck with this and I have tried numerous times with the rest with both keys that I have.
Any further suggestions welcome.
Should the convenience feature show on the data card. ?
WDB2094562T059162
• (69W) CLK 350 | Europe | North America | Japan |
Normal assembly More options
Moderator 8 050715
The front axle 2 BE609951034773
Number of Transmissions 722906 00 269366
Order number 0553791829
* Color 775U
Podzakaz * N
Production date (yymmdd) 050 713
Interior 811A
Code Body * n
The index model * 0
serial number (the first two characters - the code works) 3759238
The engine number 272960 30 129720
Delivery date (yymmdd) 050 715
WDB
209 456
2T059162
The front axle null
The front axle 2 null
Engine null
TRANSFER CASE null
Rear Axle null
Rear Axle 2 null
Number of Transmissions null
MTRSAC A2720102900
Option codes
213 PARAMETER STEERING
220 PARKTRONIC SYSTEM (PTS)
241 FRONT SEAT LH ELECTRIC ADJUSTABLE WITH MEMORY
249 AUTOMATICALLY DIPPING INSIDE REAR VIEW MIRROR
265 LINES-NO.PLATE DISCONTINUED
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
354 ANTENNA FOR TELEPHONE D / E-NET
404 MULTI-CONTOUR SEAT, FRONT LEFT
405 MULTI-CONTOUR SEAT, FRONT RIGHT
427 AUTOMATIC TRANSMISSION 7-SPEED
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
500 OUTSIDE REAR VIEW MIRROR LH AND RH FOLDING
551 ANTI-THEFT/ANTI-BREAK-IN WARNING SYSTEM
580 AIR CONDITIONING
600 HEADLAMPS - CLEANING EQUIPMENT
613 LAMP UNIT - ASSYMETRICAL, LH TRAFFIC
666 10-HOLE LIGHT ALLOY WHEELS WITH WIDE TIRES
740 BLACK SOFT TOP FABRIC 9001
772 AMG STYLING PACKAGE-FRONT SPOILER, SIDE SKIRT
806 AEJ 06/1/M/X
875 HEATED SCREEN WASH SYSTEM
882 INTERIOR SAFEGUARD / TOWING PROTECTION
926 AIR POLLUTION CONTROL D4 EU4-MEASURES
954 EQUIPMENT PACKAGE FOR AVANTGARDE VEHICLES
983 VEH. TITLE OF OWNERSHIP-OMITTED AND W / O COC PAPERS
I49 KARMANN COMPANY CONTROL CODE
M35 DISPLACEMENT 3.5 LITER
U18 AUTOMATIC CHILD SEAT RECOGNITATION (AKSE)
gh3382
