Droverunner
- Aug 2, 2017
- Location
- West Cambridgeshire
- 2007 CLK 220 CDi Sport. 2014 S-Max 2.0TDCi.
The final mid-life front suspension and brake check-over item on our 2007 CLK (220CDI Sport) Coupe is the anti-roll bar bushes. ARB and bushes look original.. bar is 22mm dia.
First... reading dire warnings on various "how to" guides I've tried to remove each bolt. They all unscrew about 5mm before getting very tight. Can't really see how you would get to oil the hidden end of the threads for successful removal?? Any ideas appreciated. I'd even wondered about drilling holes about 8mm dia in the alloy subframe adj each bolt end to see them and get oil to the threads.
Next... the anti-roll bar has moved sideways to the passenger side about 20-30mm so it's very close to rubbing on one of the suspension arms that side. Is there an unseen lip on the bar within the bushes that should stop this? In the past on other vehicles I've just levered the bar over to a central position and put on a jubilee clip to stop it from sliding through.
