W209 drivers door rattling problem
Abz
Essex
ClK270cdi, R56 Mini Cooper S , Range Rover Sport HSE (stolen) E400 (Coupe on the way)
Hi Forum,
i suspect something is lose in the drivers door causing it rattle when i close the door
it is now becoming more and more unbearable. does anyone have any advise or how to guide on tackling this problem? please help!!!
I can send you the info to remove the door card so that you can see what is wrong
A
Abz
Essex
please do malcolm, my email address is XXXXXX
You should have it and you can edit out the address
A
Abz
Essex
Thanks Malc
Alex Crow
Super Suffolk
look at the bottom face of the door, you will find several rubber grommets. pop them out and make sure the bolts above them are all tight - take care though because some are threaded adjusters and these must not be turned! there are 2x 10mm headed bolts that can come loose on these cars for some reason.
A
Abz
Essex
thanks guys, I only found a 10mm headed bolt which did not seem to fit the only place where a bolt was missing from. However, I got hold of a 12mm headed bolt which was a perfect fit and the rattling noise is no more
i don't know whether or not to further investigate where the 10mm bolt goes
