W209 Switched Live in ciggy lighter?
CLK Tim
Romey, Hampshire
W209 CLK500 2003, Altea FR
Could someone tell me (if possible) which wire is the switched live on a 2003 W209? I have pulled out the dash and I am trying to use the ciggy lighter wiring, but they are not standard colours (Ie, was looking for a yellow wire).
It's really annoying me :confused:
Thanks :D
If you have the cigar lighter out,, do you have a 3 pin socket where the lead to it plugs in
C
CLK Tim
Romey, Hampshire
I do and three striped wires, I was just going to harness the correct one for switched live but don't know which one it is.
I have one here and I will go into the workshop and check on what pin is what, and post back
With the socket facing you and the 1 pin at the top and 2 pins below , the right hand pin is the live. the left pin is ground and the top pin the lamp
C
CLK Tim
Romey, Hampshire
Thank you very much!! (Rushes off to complete car install) you are a star!
type49
:D
Standard colours?? What do you mean:confused:
What makes you think it should be yellow?
Got a feeling it could be black with a yellow tracer
They were yellow in the 129,s, and 124 I think
HelpThisDude
Essex
W203 C270CDI, R172 SLK55 AMG
All after market systems have red as perm live and yellow as the switched. Guess that is where he was coming from....
