w210 2 reverse gears ?
tezz
richmond,north yorkshire
1996 w210 e230
can someone explain how the reverse gears work on a 1996 w210 e230,..my drive is on a 1 in 6 slope and when reversing out with the gearbox switch in the s position the engine revs to 1100 before the car starts to move,..however when in the w position 1500 revs are needed before the car starts to move,..it's like a second and higher gear has been selected ?,..surely there car'nt be 2 gears can there,or is it some gearbox trickery
whitenemesis
CLS55 AMG '05
Yes, there are two reverse gear ratios.
The Hooded Claw
In the "W" position the car starts in second gear ( to stop yer skidding on ICe) in "S" mode it starts in 1st gear
The Hooded Claw
Also I'm assuming you put yer Handbrake on (I NEVER DO) just stick it in "Park" you'll probs find yer brakes are sticking on slightly.
When I engage "R" or "D" I just "Creep" very slowly no need to touch the Acc pedel
turbopete
Spennymoor
i dont think there are 2 reverse ratio's in a 210 box. i think its more a case of in W mode it allows more slip than in S mode. a bit like slipping the clutch more on a manual for the box in reverse in W mode! as far as im aware, its only the 7g box that has 2 reverse speeds and the 210 was fitted with the earlier box 722.6? i think!
T
tezz
1996 w210 e230
i learn something every day on this wonderfull forum,.thank you both
All 722.6 boxes have two reverse speeds. Also the car will not roll back on hills in W
turbopete
Spennymoor
well i didnt know that! maybe i should use W when reversing to save fuel! :lol::lol::rolleyes::rolleyes:
www.ckinsurance.co.uk
