jibcl500
- Oct 22, 2005
- Age
- 56
- Location
- Cambridgeshire
- CL500,ML55,SLK280
I have a customers w210 300 diesel in for some work, These are the problems Im having with it.
On cold or warm start the car drives well but it feels sluggish, after a few miles if I accelerate hard from stand still the car hangs in 2nd gear and wont change to 3rd.
The engine then struggles and the mph drops and the car wont accelerate, road speed as low as 15mph and no throttle response.
whilst the engine revs are highish there is plently of white blueish smoke but this isnt apparent on a first start only when the performace drops off.
Performance or problems with the car are the same with the MAF connected or disconnected.
With the bonnet open and ticking over there is an occasional crack but not all the time, Ive listened to the injectors with a screw driver and some sound slightly different to others.
There is a constant stream of air bubbles in the fuel lines with the engine running but no problems starting the car.
Ive run diags and the every system on the car had faults !!!!!! Ive cleared all the fault codes but some remain and I cant clear them, EGS gearbox and Aircon but these are not related.
My thoughts are possibly the injectors are failing or the seals are leaking but there is no black death on top of the engine etc so seals poss not a problem.
Any help please!!!!
jib
Any help please!!!!
jib
