w210 300TD towing
r1lunn
sussex
Hi there all i have got a 1998 E300TD and wont to tow a car trailer with it but have been informed that i will need to fit a oil cooler and remove the air con to do this. has any one done this or is it just more money for nothing
cheers
Nick
Bolide
www.w124.co.uk
BMW 525 Diesel Touring
Informed by whom?
I believe the car already has a gearbox oil cooler. The engine oil cooling system would be more than adequate as it is
The a/c does dump heat into the cooling system. But if oil & water temperatures rise there's an easy solution - turn the a/c off
Nick Froome
www.w124.co.uk
R
r1lunn
sussex
i was told by a merc dealer and also some towbar fitting companies that it may need this stuff just wondered if any one had towed with out doing this
jberks
people have towed with 300td's for years. Possibly if you were towing in the hight of summer on a greek island you may need a bit of extra cooling but in the UK? - nah All Es I've had have had oil coolers as standard so I don't see why yours would be any different. Easy to check though.
I would get the gearbox oil and filters changed though - and possibly the cooling system flushed too - just sensible preventative maintenace given it's age.
Mike2513
Longton, Stoke-on-Trent, Staffordshire.
Vito111CDI Long Dualiner
Hi I use my 1999 w210 E300TD to tow a large twin axle caravan with no problem, even when returning from France fully loaded (1700KG), temp. sometimes creeps upto 3/4 mark but with A.C. turned off never gets to red mark. Only advice I had was to change A.T.F and filter ever 2 years. Hope this canbe of some help.
R
r1lunn
sussex
thanks
thank you all for your advise much appreciated
johnny2mercs
New Registration
hampshire
hello from a new member:D
i have never had a problem towing with any of the Mercedes i have owned.
as suggested above, the temp may get to just above normal, especially on a gradient, but its no big issue, and returns to normal on the flat.
i would be interested in comments about the price the main dealers are quoting for towbar fitting. i was quoted £2k for my ML. they said if i didnt buy their fitting kit the electrics would not work. went to my local towbar fitters who told me they had done dozens of MLs, without a problem (provided you know what you are doing!). cost £275 fitted, have had no problems.
now i have found this forum, i hope to look in regularly.
cheers
john
