robs-mbz
- Dec 9, 2006
- Location
- Newcastle under Lyme
- 1997 E300TD
The air conditioning on my W210 has never worked, I put it down to there being zero pressure in the system. This morning I bought one of the Halfords refill/sealer cans, charged up the system to 2.2 bar (27psi), the clutch on the compressor still won't pull in, fuses 4 and 7 in the fuse box are ok, I have pressure at the bleed screw right next to the pressure sensor, my hope is that its just the pressure sensor that is faulty. Are there any checks I can do to test that the sensor is working? My first thought was to short out the connections to the sensor to see if I could get the clutch to energise, so far I've resisted as I don't want to cause any more damage! Is the sensor a simple pressure switch or a pressure transducer, there are three wires connected.
Any help would be appreciated, please dont reply with "take it to a main agents or an Indy"
