Irresistance
- Apr 25, 2009
- Location
- Gdansk, Poland
- 2004 W220 320CDI
Hi All,
Ever since I have my Benz, the illumination of the Air Con control unit (The fancy digital one) is not working. Now I have been assuming that it just has a broken bulb and I'll need to get a different one (not expensive here in PL) but just recently I read this:
http://www.scribd.com/doc/20752205/Mercedes-Benz-140-and-210-Climate-Control
(here for a PDF version, although with less info: http://www.programainc.com/docs/140210ac.pdf)
Now - they say on both pages: "If you have a problem with ECT data or night illumination with the climate control panel you do not have the K1 and
K2 values programmed correctly. THIS IS NOT A PROBLEM WITH THE CLIMATE CONTROL PANEL."
Then they proceed to give a McGuyver-like programming tutorial. Hold this and that key while blah blah - all seems doable but I am just curious - has anyone ever had this problem, and fixed it by doing the procedure described above?
Coz I am happy to buy a new (second hand) panel for 80 quid but if the problem is te programming then it wouldnt do a damn thing... hence my question
Thanks people
W
Thanks people
W
