W210 - E320 Immobiliser Problem
John472
I recenly found that my battery had gone flat.
I recharged the battery on the car and as it charged up the alarm was set off. Eventually this stopped, then I noticed at buzzing noise from the electrics box at the right hand side, rear of the engine bay.
I opened the box up and moved some of the wires and the buzzing stopped.
I continued to charge the battery. When it was fully charged, I tried to start the car but it would not start. The dash panel lights up an d looks as normal but the engine does not crank when the key is turned to start.
I think it is an electronic fault but I am not sure where to start. I am good with elecronics and have a multimeter etc but have no circuit infomation.
Can anyone help?
John
J
John472
  • #2
This was caused by water entering the waterproof ECU box and caused dammage to the engine ecu anf assocated connectors.
John
I will look up the faults next week to see if known
BlackC55
South coast
C43
Try your spare key.
If not that I suspect the ignition switch as gone down.
have you checked the fuses?
J
John472
Thanks for you reply.
Unfortunately the problem is due to water, that got in to the ecu box.
The ecu is suspect and the connectors have been damaged.
I am still amazed that this could have happened.
A MB dealer quoted me circa 1500 pounds to repair.
John
