AdrianDW
2000 MY has suddenly developed madly flashing indicator on the right only. Bulb is suspected as the main headlamp mounted unit appears dead - but no message from computer - so is it the relay maybe?
This sudden occurrence has been accompanied by what sounds like a detached component knocking about inside the steering column shroud. At the last service I complained about a rubbing / squeaking noise from the shroud area and the stealer's response was to suggest it was an part of the multifunction switch and to replace (£45 + £70 labour).
Anyone any thoughts, and especially, does anyone know how to get the column shroud off so I can get at the switch?
Cheers muchly.
Cheers muchly.
