W210 key not recongized
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by endrit abdia, Nov 17, 2012.
  1. endrit abdia
    endrit abdia New Member
    3
    Nov 17, 2012
    Your Mercedes:
    w210
    my w210 key has got a problem.....even though when i prees lock button the light works, the car doesnt lock....and when i try to ignite it .....it doesnt ignite.....it doesnt recognize the key........what can i do?
  2. television
    television Always remembered RIP
    164,074
    309
    Your Mercedes:
    Does the key actually turn in the ignition lock
  3. OP
    endrit abdia
    3
    Nov 17, 2012
    Your Mercedes:
    w210
    the car has 2 keys.....a reserve and the one that has the problem that has been working for some time now.....i can enter the key but because it isnt recognised it cant turn.....the reserve key work but i want this one to work too
  4. television
    164,074
    309
    Your Mercedes:
    If one of the long keys and it will not turn, then the transponder coil broken, but if not locking as well it could be past its best and and new one required
  5. OP
    endrit abdia
    3
    Nov 17, 2012
    Your Mercedes:
    w210
  6. television
    164,074
    309
    Your Mercedes:
    You could ask mark if he can do something cheaper than MB
  7. Mark@RMK
    Mark@RMK Senior Member Authorised Forum Supporter
    534
    8
    Jan 4, 2010
    Birmingham
    Your Mercedes:
    115CDi Vito
    I can reprogram the older style keys to work fully again!
    Its life is around 100,000 uses and that's usually around 10/12 years of using the car!
    Mark
Share This Page
