Brake pedal causes indication that can not be cancelled, all lamps ok. I changed pedal switch which fixed it last time. Front ns side lamp comes on with brake pedal what is it?? maybe clashing contact in rear lampholders are again the cause? I had the problem once before with the holders and the front ns side lamp coming on and bent them and fixed it. I was told rear lamp holders have been redesigned - have they?? My Austin seven had no lamp failure warning and never needed it is the most infurinating feature of this good car.
