Smaltze
Ive lowered my car a while back on recommended lowering springs and adjusted the self leveling by loosening the clamp on the sway bar. however when i did it i broke it and had to make a new clamp. It has worked and the SLS does work under load as it should.
however the car does sit very very low and i get a huge bounce when going over big dips. its only a problem on big dips and bumps i dont notice it elsewhere, but where im having to drive lately is very bumpy and its getting to me. its as though there is no dampening.
Will raising the height A - soften the ride, or does the ride height not matter as i know the damping comes from the other bit, i forget the name. and B - will it affect the camber if i bring it back up since its currently off from lowering it and would be nice to have it back closer to normal.
It would be nice to have it up by an inch or so.
Im curious as to how i get the SLS height set upward. since i remember when i did it i took it off completely and then bolted it back on where it is, so i assume its sat at its lowest setting.
Thanks.
Thanks.
