w210 rear bumper removal?
jazzman
suffolk
I need to repair os rear bumper after some muppet could not navigate their way out of supermarket parking space without sideswiping my car,of course did not bother to leave details or owt.
Anyway, cracked light cluster which has to be replaced and scraped (push in?) o/s part of bumper that needs to come out and be sprayed also damaged chrome trim that needs replacing.
Looks like the bumper has to come off to gain access unless someone knows otherwise.
Any help locating removal bolts is appreciated!
Car is E220 cdi avantgarde year 2000.
Many Thanks
Gary.
Estate or saloon gary
jazzman
suffolk
Sorry forgot to specify car is a 4 door saloon.
OK activate your Email address in your user CP and save the changes at the bottom of the page.
Then I can send you the paper
jazzman
suffolk
Thanks! Malcolm
Think i have activated e-mail, please inform if still can not send.
Cheers!
Gary
I have sent it, it covers cars up to 05 99 :D So Email works fine thank you
jibcl500
Cambridgeshire
CL500,ML55,SLK280
Jazzman
Im breaking W210 Saloon at the moment if you need any parts then ask.
jib
jazzman
suffolk
Thanks Malcolm,
I was able to prise out the bumper insert without having to remove the bumper in the end.
Bit tricky but patience and using right tools made it possible.
Tip: Start from the end near the wheel arch if taking out side inserts as there is a slide in tab that end.
