Michael1983
- Oct 5, 2021
- 2002 E320 cdi avantgarde estate
Hello,
I recently purchased a 2002 e320cdi avantgarde estate when I got the car it didn't feel quite as good as it should in the ride quality so I first changed the rust rear springs and the rather old looking front shocks not knowing much about the self levelling system but the car was still road bad and local mechanic didn't know much about these hydraulic systems but he said it felt too hard.
I've now purchased new spheres, fluid and filter to hopefully solve this problem but the car seems to sit quite low both front and rear so new springs are going into the front as I found the current ones had broken on the last rung, I am also replacing the spring shims with the rears going up a bur.
My query relates to adjusting the self levelling system on the back as its currently on the higher setting on the valve and I've tested the system so I know it all works but how much can I adjust it?
I would like some more height but at the same time I don't want to risk damaging the new spheres by taking too much weight off the springs.
