glenluceblue
Same old chestnut. I've an E200 kompressor (late 2000) with a strange problem with the Servo. The brakes are excellent and normally I have no problems but here is the fault I'm experiencing;
Start car with foot lightly on brake - you can feel the Servo kick in. If I then shift into reverse gear and let my foot off the brake (foot not on accelerator) then I lose the Servo. If I then go into neutral or park and rev slightly the servo returns. If I start up and put the car in reverse, then into drive (still without touching the accelerator then I lose the Servo, but again as soon as the revs pick up the Servo comes home to mama !. If I start up and go straight to drive (without the accelerator) and inch forward then the Servo is fine. The only time this would ever be a problem is if I was boxed in between cars and needed some nimble manouvering between drive and reverse.
The last time I posted I was given some good advice regarding a test for the Non return valve between the Servo and the vacuum pump which seemed to indicate the NRV was healthy. I have spoken to mechanic offshore today who reckons when you move into reverse the engine idle speed drops and that this may lessen the vacuum created by the pump and advises, if possible, to up the idle speed a little.
Does this make sense ? Can the idle speed be altered or am I "fly by wire" ?
Has anyone had anything like this happen to them ?
I'm still offshore so cannot carry out any tests but this is doing my head in.
Help me please
Help me please
