JeremyG
I've got a nasty problem with my '96 W210 E230 estate - the steering lock won't unlock.
This happened this evening - stopped the engine but left the key in the lock. When I came to restart, the key would not turn.
The following applies:
1) Neither of my keys will turn the ignition
2) Both keys fit in and come out of the lock normally
3) Both keys will lock/unlock the doors normally
4) I have the earlier single-button, blade key type
5) When I put either key in the lock or remove it, there is a faint click that sounds like a relay or solenoid (immobiliser arming/disarming?)
The security system has been doing a couple of odd things recently:
1) Locking the car always works fine. But when unlocking, I sometimes get the green and red warning lights in the mirror flashing - not simultaneously and not alternating, but with an odd flashing pattern
2) When opening the passenger door with the car unlocked normally and the drivers door already open, the alarm went off. The same thing happened a few days ago.
3) For a few weeks now, when I lock the car there's been a multiple clunking noise from the petrol flap area - assume this is the petrol flap lock playing up
Not sure if any of the above are related to the lock problem - but has anyone got any ideas on how to release the lock?
Would a battery disconnect/reconnect cycle help?
Cheers,
Jeremy
Cheers,
Jeremy
