brandwooddixon
- Jul 31, 2006
- Location
- Wolverhampton
- S63 Coupe 2014
to comment on this thread please use this link
http://forums.mercedesclub.org.uk/showthread.php?t=31657
I have a 1998 E430 fitted with an electric tilt and slide sunroof. One day whilst trying to slide the sunroof back it became stuck after moving about 4 inches or so and procedded to make an horrific clacking and thunping noise! I managed to close it again and as my car had automatic climate control fitted anyway I decided to leave it until the next service.
Boy was I in for a shock. MB quoted me £3500 to fit an entirely new sunroof "cassette" and as the cause was down to the flexidrives used to power the sunroof, which MB erfer to as cables (even though they push as well as pull) it wouldn't be covered by the warrenty. So I decided to leave it.
I have since learned that this is a common problem with the W210. Through lack of use the tracks become gummed up, the roof sticks at some point and the drive "cables" buckle, popping out beneath a small plastic cover.
This cover is fixed in place by a self tapping screw at one end. A simple fix is to place another self tapper at the other end. I tried this, but in my case the runners were too gummed and the cable too buckled for it to work.
So I left it.
Until yesterday.
I decided to replace the cables and get my sunroof working. MB dealers wont do this anymore as the work is then under 12 month warrenty and lack of use will have owners returning before the warrenty expires for the work to be performed for free.
All told it took me about 4 hours, but that included taking pictures with my new camera and visiting the local motorfactors for some unexpected bolts - more of that later. I reckon that it should take about 2.5 to 3 hours to do normally.
Here's what you'll need:
New cables : MA210 780 01 89 and MA210 780 00 89 £22.70 each (cables are handed).
Possibly 2xM4 bolts about 8mm long.
T25 Torx screwdriver
10mm socket.
Small phillips screwdriver.
Flat bladed screwdriver or other implement for prising things apart.
Lubricant to regrease the tracks - MB recommend Klueber Polylub GLY801 but only comes in big tins from the dealer. I used some dry setting, teflon bicycle chain, spray lubricant instead. Ultimately it'll attract less dust and dirt.
So I left it.
Until yesterday.
10mm socket.
