Hello,
I wonder if I could ask if people would be kind enough to help me with this problem. I have a '96 W210 E280 which developed an odd cranking delay that has been present for a while now - a year or more in fact, but the car only gets used occasionally over the summer.
I first noticed a very small delay (<500ms) between turning the key to the crank position and the starter activating. Odd, I thought, but then the next few times it was normal. Then it occurred again and the time delay became a little longer (say 1 second) - after that it was normal for a while. Over time this situation continued and escalated such that, say one or two times out of ten or twenty starting attempts I get this delay - and the delay has tended to become longer - 20-30 seconds even (and in one case a couple of minutes).
Now it apparently makes no difference if I operate the ignition/starter switch on/off/on or waggle the key etc. All I have to do is switch it to the crank position and wait. There's no obvious sound, no unusual indications, but after a delay (if it's one of those occasions when a delay occurs) it will suddenly crank and fire up as normal. I've tried all forms of inducement I can think of which I can do from the driver's seat but nothing helps - all I need to do is just sit there with the key held in crank position and wait.
I've asked several people about this and no one has been able to suggest anything definite - and any comments I've had all differ or don't seem to make sense.
I can find nothing immediately obvious to cause this and haven't had time to remove the starter or anything like that, but wiring looks fine as far as I can see. The only thing that I have found that might have had any effect is when I've tried multiple successive starter activations - not actually starting the engine but just enough to fire the starter into engagement and commence cranking - if I do this about 10 times it seems to extend the time (i.e. the number of normal cranking occasions) until the next recurrence of the delay.
Unfortunately I don't have a wiring diagram to enable me to see what is in the circuit or where I can access connections to test the system. And as it's intermittent, the fault won't occur when I'd like to help with diagnostics! The other thing is that there's an after-market immobiliser fitted of which I've no details - I don't know if that is in the crank circuit or not, but experience seems to suggest this is not the problem as I can't associate it with the difficulty.
So, has anyone any clues? Or any wiring diagrams?
I don't really want to take this into a dealership as I think I'd end up with a very big bill and I don't think the value of the car justifies it. I have a feeling it's something simple... I could be wrong!
Any assistance greatly appreciated.
Thanks, Bob
Thanks, Bob
