W210 - Unusual tyre wear
R
richardgill
The latest set of Continentals have worn really quickly on the rear inside edge of both rear wheels but more on the rear nearside wheel. I've noticed this before and my local Indie says he's seen this before on these models. Anyone know why? Basically this has written off a perfectly good pair of tyres well before their time and I'd like to find out why.
brandwooddixon
Wolverhampton
S63 Coupe 2014
It's likely that the suspension bushings are worn out and need replacing. Typically thrust arms go first.
I gather that these can be replaced fairly cheaply.
jberks
My 211 does this too. The first part of the rear tyres to wear out is always the inner edges.
what size wheels and tyres are you running?
The wider ones tend to be cambered in at the top, giving better grip in the corners but putting excessive wear on the inner edge. You can counter it to some extent by increasing the pressures by 2 psi or so. I managed to get the last set to wear a lot more evenly by running at 36psi. The inner edge was still bald, but the middle wasn't too far behind and whilst the outer still looked ok, this just meant they looked ok to passing policemen whilst I waited for the new set to arrive! (New set now fitted).
R
richardgill
Running 235 x 45R17s and pressure 31psi although I have run these at 42 when fully loaded - family on holiday etc. Just had good service and MOT and bushes fine.
