w210 V6 mystery clip
davidash
Durban South Africa
I recently changed the 12 sparkplugs in my E280 (with great difficulty!) and after putting everything back, I discovered a clip under the car which probably came adrift while I was busy with the job. I have searced the engine bay but cannot seem to find an appropriate place for the clip.
I have taken a picture of the clip, which measures 2.5cm. It is clearly meant to clip onto two small pipes of different guages.The clip sections swivel.
Any bright ideas?
Many thanks
Davidash
Aussie Nick
Melbourne...Australia
I would suggest that the clip is to keep a hose or metal pipe separated from one of the spark plug leads. You will need to look where the two come, or may come together. I suspect that the larger clip is attached to a metal pipe rather than a rubber hose as this would potentially cause a problem more so than contact with a rubber hose.
I think this goes without saying.... but do not touch the leads with the motor running otherwise you may experience, first hand why the two parts were meant to remain separate.
