Fairly straightforward, remove the front bumper and the wing bolts, the only awkward ones are the two phillips headed screws under the wing to sill moulding, use a good quality screwdriver to remove them..the inner wheel arch can be remove before or after, if it has the rubber seal around the wing edge clean it well with waxoyl or similar and smear plently on the wing inner edge before replacing ..after painting of course..
Comand Online Ltd is a specialist supplier of Mercedes Navigation Disks,
Phone & Bluetooth, iPod, DAB, CD and other COMAND retrofit parts to
enhance your vehicle.www.comandonline.co.uk
