W210 xenon headlights.
E300tdHighlander
Highlands Scotland
W210 300td estate.
Sure this has been mentioned before but i'll ask anyway:)
My car has LHD lights fitted and as it is coming up to MOT time i'm looking for an easy way to change the beam pattern to RHD spec. I know that older Mercedes and Bmws it was bulit into the headlight ie flip a lever,adjust bulb holder location.
Is it as simple as this?
Chas
Scotland
S320
Switch ignition and lights off !! Open the dipped beam headlight cover, and look for a small lever, carefully move it in the opposite direction.
Your dipped beam normally looks like this in RHD cars
When the levers are moved the beam will either be horizontal or as the picture. i.e. kick up 15 degrees to the left
Chas
Scotland
S320
Use a torch, it might be hard to see right inside. Failing that your car may not have the lever
whitenemesis
CLS55 AMG '05
W210 does not have this adjustment lever
Just confirming Peters post above, not on the 210
LYNALL
Kent
I spent ****** ages trying to find the answer to this a few months ago and basically your screwed, no lever.
Every man and there dog said there was a lever.
Have a look on e bay was some rhd xenons a few weeks ago.
Lynall
E
E300tdHighlander
Highlands Scotland
W210 300td estate.
I'll use the sticky beam deflectors this year, spent enough over the last wee while without buying headlights.
