w210E320 Starting/power issue....
pikeydave
Dorset
Evening forum,
here's the problem.
First of all the vehicle in question.
99 W210 E320 v6petrol auto Av.Estate 98k
Problem.
With no warning car refuses to start.
Symptoms.
Starter engages for a split second (turning eng. over) then disengages.
Will keep eng/diseng if you hold the key to start pos.
Clues for troubleshooting.
Hotwire to engage starter and it spins over fine.
Wiring fuel pump live + starter mod above still won't fire.
Any suggestions welcome.
Take a look at the rev counter to see if the needle flicks up when the car will not start
pikeydave
pikeydave
Dorset
Evening Malcolm, I'll give it a go in the morning. The car's been parked up for ages with this fault and I took the battery off it.
What could this lead to?
Cheers.
Dave
If the rev counter flicks up to the 2k mark when the car will not start it means that the starter ring has static on it and it needs greasing, the static gives a false reading to the CPS
pikeydave
pikeydave
Dorset
Despite the starter instantly engaging?
Yes the starter engages, the CPs gives a false reading and the starter thinks the car is running and flips straight out before it has started
pikeydave
pikeydave
Dorset
Sounds plausible, I'll try and squirt some lube in there tomorrow once Dorset has dried out a bit!
Dorset dried out, you must be joking it here all week so they say:rolleyes:
pikeydave
pikeydave
Dorset
I'd have been drier today if I'd been an extra in Waterworld...
pikeydave
pikeydave
Dorset
Battery back on. Same clunk..clunk..clunk of starter engagement BUT not a flicker from the rev counter needle...
www.W140.co.uk&www.r129.co
