w211 006 E, Audio 50 Fault
Swampy_B
Help, Help, oh please help.
My main stealer has no knowledge of this fault so i aint going there to be told new headunit needed, (robbing *******)
My headunit occasionally shuts down, the dash still shows all the functions but the headunit appears to power down.
then amazing as it is powers up and all fine for a short while until it has another funny episode.
This along with the satnav been drastically wrong for example i was staring at Liverpool John Lennon Airport when my SatNav thought i was in Leeds.
I've had a dead battery recently and recharged and all was fine until it went to MB for MOT. not pointing fingers here but it aint the 1st time a new fault has occured after been robbed by them.
A little guidance is greatly appreiciated.
I'll let you know how i get on.
Ellsy Tanners
Mars
If the sat navi is permenatly wrong then your antena is possibly knackered, not picking up the correct gps signals.
its possible you have a fault with the audio gateway for the head unit fault. this could be as simple as a coding issue, but will have to be fault read and diagnosis with a star.
Autofix
Coin, malaga, Spain
www.kaneautomotive.net
SL600
Some issues can be cured by powering down and rebooting, i.e. pull the fuse for a few seconds. Software update can also fix this. Other than this it will need to go on a star tester.
Swampy_B
Thanks, i'll get them checked out.
progress will be posted
Swampy_B
Fixed
Well i fixed the fault by connecting to star and resetting the computer.
problem fixed and sat nav behaves.
oh the joys of modern technology.
cheers guys.
I have a magnetic mounted aerial on the roof would this have an effect on the fm signal as it is a bit fuzzy but even without aerial it is still a little fuzzy but amplified by the mag-mount
what would be a simple solution without rerouting the aerial.
