W211 220 cdi
pomm001
leicester
SL 500 R231 A clas W169
I now comute a fair bit on the M1 and M25 and there is a quite a bit of slow traffic.
What i have noticed is that on very light throttle once the box has selected top gear that under certain conditions ie very light throttle with the slightest of incline so there is the smallest of load on the engine it tends to very gently surge. I f you look at the rev counter you can see this slight climbing and falling.
Other conditions its not there, its difficult to find the 'spot'
Question:
Have i found a 'hole' in the calibration or do you think there is a sensor going down somewhere.
Its quite difficult to replicate but the M25 seems to highlight it a little more.
Other than that it runs great, 50 mpg, pull clean from any revs
any ideas
This is a hard one and something not been up before
Xtractorfan
S class
I honestly dont think you have a problem, but well worth having it checked on a star machine just to allay any fears..
pomm001
pomm001
leicester
its in at the stealer for a service soon so if it goes on the star machine will ask to see if there are any flags up
As i said its difficult to replicate , just wondered if anyone had come across it
bill3862
Pomm001
I also have 2005 E220cdi with 38000 miles - recent gear box oil/filter change and changes are smooth - however, in slow traffic (20-30mph crawling and stop start) using a light throttle mine also does the same more pronounced when gear box is in S mode and not noticeable in C mode.
It seems the car is hunting right gear and cannot quite make its mind up with regard to which is the correct gear for situation - its a very smooth slight surge and I do feel nothing to worry about.
I also thought I read somewhere that these gear boxes adjust themselves to drivers style and maybe slower stop start driving is not recognised instantly??
Hope this helps
Bill
