w211 220cdi inlet manifold
SHAMGIT
york
w211 2008 220cdi
i have a facelift model w211.. 220cdi ,170hp ,2006 ...am searching for an inlet manifold with the flaps,... ...looking on e bay i am coming up with 2 different part numbers
a646 090 2237.....a646 090 2437.......
for the w204 c class the part number is a646 090 23 37..
does anyone have the correct part number or will any fit.
my other question is cant find any details about tying the swirl flaps open for the 220cdi, there is some information for the v6 280cdi and bypassing the electrics..
any help would be much appreciated
SHAMGIT
york
w211 2008 220cdi
  • #2
getting desperate fo information just to confirm for this vehicle the part number a646 090 2437....will the others fit
Just a thought , but if you take off your inlet manifold , will it not have a part number on it , then you can order the correct one , I know it will create a delivery delay but it removes the risk of buying the wrong part ?
SHAMGIT
york
w211 2008 220cdi
have checked with the stealer,,,
that is the correct part number i am showing,,
the other part numbers are coming up on e bay and when i put car details in to the adverts it says they are compatible with my vehicle,,nobody seams to be able to confirm this,
was hoping to purchase one in advance ,clean it and tie back the swirl flaps allowing a quicker change round then sell my old one on....
SHAMGIT
york
w211 2008 220cdi
check out thread.....w211 pressure control valve,
car a lot better after replacing inlet manifold...
