W211 air suspension question
Profdriver
New Registration
W211 2008
Hello and thanks in advance.
My REAR driver side suspension does not go up fully anymore after FRONT left wheel bearing was replaced. It was in the garage with front end lifted for 2 days until we found a hub and bearing.
When I went to collect the car front left still looked raised even though it wasnt.
When the car started it was then almost level at the back.
Now when the car is switched off the rear driver side is down significantly and front left is raised.
Can someone offer advice please. Thanks
mioba
Nottingham and Köln
Get back to the garage and ask them to plug it into star and get it calibrated.
Wearsafoxhat
Sunny Hampshire by the sea
E63 :S213, SL500 :R129 , V220
Has the car got Airmatic ?.
Small leak in rear driver side airbag, damaged or stuck linkage on front level sensor where the work has been carried out..
00slk
Cambridgeshire UK
I followed a 57 plate s211 yesterday leaning 45degrees to the left, either a poorly loaded super heavy load or both front and rear n/s shocks completely deflated :shock: I know how that ride would feel o_O
steveq
Dublin
2011 Merc S212 E220CDI Estate; Tesla Model 3; 1965 W113 Merc 230SL Pagoda
All E Class estates have Self Levelling Suspension at the rear as standard. If a S211 is lopsided one of the air bellows must have failed or maybe the height sensor has failed.
