W211 Battery Charging
Discussion in 'Electrics, Vacuum, Ignition and ECU' started by matthew k, Nov 6, 2019.
  1. matthew k
    matthew k Senior Member
    492
    156
    Feb 4, 2015
    Winchester Hampshire
    Your Mercedes:
    2005 320 cdi Sport 7 seat estate
    I wonder if anyone has advice on charging my battery. I've had the 'convinience' warning coming up for a while now for the first few miles of use. I put this down to local use and a tired battery. I've actually let my tax and insurance lapse this months as I'm not using the car for a while so I'd like to charge the battery.
    Is there anything in particular I should know, does the battery need to be disconnected beforehand? I must say this is my second W211 and they do seem hard on batteries. Thanks
  2. ajlsl600
    ajlsl600 Senior Member
    4,055
    1,727
    Nov 18, 2013
    france
    Your Mercedes:
    buy a ctek and just follow the instructions .simples .
  3. Tony Dyson
    Tony Dyson Senior Member
    1,875
    858
    Aug 26, 2018
    God's Country
    Your Mercedes:
    2014 C 220 CDI W204 OM 651
    You can leave the battery connected to the car providing the charge voltage doesn't exceed 14.5v and if it's not a Smart Charger stop charging when demand falls off to near zero on your charge indicator.
    matthew k likes this.
  4. OP
    matthew k
    492
    156
    Feb 4, 2015
    Your Mercedes:
    Ok thanks, so charging in situ isn't going to dry anything? It's an estate so I need to work out how to get access, not sure.
  5. AMGeed
    AMGeed Senior Member
    6,521
    2,699
    Jan 18, 2009
    Poole, Dorset
    Your Mercedes:
    2014 W212 E63 Biturbo
    If you are getting the convenience features message often, check the voltage of your aux battery under the pollen filter. Seems lots of E class owners forget or don't know about this second battery. If its on the way out it can give that message as well as the main battery.
    Tayna sell a Varta aux battery for under £45 delivered, half the price of a Fiamm OEM.
    As above, no problem to charge either battery insitu. Neg terminal connected first and removed last.
  6. OP
    matthew k
    492
    156
    Feb 4, 2015
    Your Mercedes:
    The aux battery was changed in the last 3 years by Mercedes I think. The car has been sluggish to start. Thanks for the information, I'll charge it today.
    AMGeed likes this.
  7. mioba
    mioba Senior Member
    1,304
    287
    Feb 19, 2006
    Nottingham
    Your Mercedes:
    W124/1994/E200, W220/2004/S320CDI, W205/2016/C200, W447/2017/3.0 CDI
    Cold weather identifies weak batteries immediately.
    If your having starting issues its the main battery.
    What brand of battery have you in there now and how old is it.
  8. OP
    matthew k
    492
    156
    Feb 4, 2015
    Your Mercedes:
    It's a Verta Mercedes one I think, not sure how old it is. Agreed the cold weather reduces the battery's capacity and increases the torque required. I've charged it, and it seems to crank up normally. I'm sure it's on it's last legs though!
    There does seem to be some cheap (agm) replacements available on Ebay, I'm not keen on spending £300! :)
    Would something like this do? https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/312754900991
  9. Tony Dyson
    1,875
    858
    Aug 26, 2018
    God's Country
    Your Mercedes:
  10. OP
    matthew k
    492
    156
    Feb 4, 2015
    Your Mercedes:
    Thanks, and actually you make a good point, it could be my alternator!!! There is a bit of slight flickering from the interior lights at idle, humm, I wonder?
    Om642 148,000 miles
    sonic likes this.
  11. sonic
    sonic Senior Member
    1,535
    701
    Nov 21, 2009
    Staffordshire
    Your Mercedes:
    E350CDI, SLC250d, FJR 1300
    Quite often I don't use my E class for over a month, so after about 3 weeks I put it on charge using a standard 5 amp charger.
    6 to 8 hours will bring the charge rate down to under 1 amp, so I then disconnect. Never had a problem.
    If you need a battery then Tayna are great on price & service.
  12. EmilysDad
    EmilysDad Senior Member
    8,846
    2,483
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    The battery I replaced on my R Class had the date stamped on the top one of the posts.
  13. OP
    matthew k
    492
    156
    Feb 4, 2015
    Your Mercedes:
    Ok, so I've started the car a week later, (in my drive not using it at the moment) and it really struggled. When it started after a couple of minutes idling it stuttered for a second, and is running normally now, I'm sitting in it, letting it warm up.
    So is this typical knackered battery stuff, or do I have a battery draining issue? After ten minutes idling I turned it off and it span up easily, this suggests to me the alternator isn't the issue? Thanks!!
  14. sonic
    sonic Senior Member
    1,535
    701
    Nov 21, 2009
    Staffordshire
    Your Mercedes:
    From what you say sounds like the battery is starting to loose its capacity, particularly as its starts after warming up. Have you a charger? If so leave it on charge overnight & try starting it in the morning?
  15. OP
    matthew k
    492
    156
    Feb 4, 2015
    Your Mercedes:
    Yeah, and maybe two weeks of disuse has finished it off. I charged it a week ago, and it was very sluggish. I'll try starting it tomorrow, I just have a dread of slow drains, I know how hard they are to diagnose.
  16. sonic
    sonic Senior Member
    1,535
    701
    Nov 21, 2009
    Staffordshire
    Your Mercedes:
    The first cold weather always finds a weak battery.
  17. EmilysDad
    8,846
    2,483
    May 8, 2012
    Bury Lancs
    Your Mercedes:
    ML350
    sonic and matthew k like this.
  18. OP
    matthew k
    492
    156
    Feb 4, 2015
    Your Mercedes:
    That's a good point, thanks
  19. OP
    matthew k
    492
    156
    Feb 4, 2015
    Your Mercedes:
    EmilysDad likes this.
  20. onefortheroad
    onefortheroad Senior Member
    1,261
    426
    Dec 8, 2015
    uk.
    Your Mercedes:
    c207 e350 cdi 2017 . ford kuga 65 plate awd powershift .
    If it helps i put a new battery on a w211 and 2 weeks of short trips to work put the convenience functions light on. It was winter time also. I was charging mine once a month.
Share This Page
