Darrendazza
- Mar 3, 2020
- E280 2007 v6cdi
Just checked this cc as it was just to small 5mm Id so I’m wondering if that what was causing the oil up the dipstick tube got all 12mm pipe n connectors but no good if going though a 5mm cc in/outlet that’s a 10mm inlet in pic 3 with the (12mm meant to be) sitting inside it lol so taken out now argue with seller then get the cc u linked me to see how she goes from thereWhile running...also check the amount of vapour......have a rag handy as oil will splash out, splashing oil is normal from the cam/chain directly under.
Just I'm about to redue my oil catch can using MUCH biger internal diameter pipe.....any build up of blowby pressure in the crank case will I think restrict oil flow back to the sump from the turbo oil feed....its just a theory......it will then be forced out of the rear seal...only drips but on idle will build up and smoke.....but while driving would be un-noticable!
So would be interested in someone else with the same or similar issue doing the same test....
